What is this? (pictures) - Ford Powerstroke Diesel Forum
Old 03-11-2012, 05:24 PM
My truck has a slight pull to the right, and I hear a noise around 15 mph that sounds like dimes and nickels being tossed around... I looked around to try and see any visible problems and I saw this... It's like this on both sides. What is this? thanks.
Old 03-11-2012, 05:26 PM
Winning DUHHH
dust seals popped out.....common issue
But nothing to do with your issues
Old 03-11-2012, 05:27 PM
Is this related to my clanging issue? So it's no big deal?
Old 03-11-2012, 05:30 PM
Winning DUHHH
No relation to the clanging issues no....And no real issue here....Its meant to keep debris out of the axle tubes....But I think every truck has had them pop out
Old 03-11-2012, 05:33 PM
Well I appreciate it man.. Do you have any idea what would be causing the clanging change noise? I only noticed it after I put on these mud tires... The guys at the tire shop said my back spring was kicked out so they beat it in to where it's supposed to be (I have no idea)... Could that be it? I'm at a loss.
Old 03-11-2012, 05:34 PM
yea mine are pooped out... one time I got a rock back in behind my brake shield and inside the rotor and it clanked around like that... just something to check. Dont know about the pull
Old 03-11-2012, 05:40 PM
Was it hard to get it out ? I figured if it was the wheel hub, it would be making noises at all speeds, and when I turned the wheel.. So that cancels it.. I need to jack it up but just haven't had time.
Old 03-11-2012, 05:43 PM
yeah I think you're right... It sounds almost exactly like this just louder at 15 mph.
