Are my stabilizers ok? - Ford Powerstroke Diesel Forum
Old 02-12-2012, 07:43 PM
All other pictures of stabilizers I've seen on trucks are straight across, whereas mine are at a slight angle. Is this ok? Thanks!
Are my stabilizers ok?-419008_338874509486198_100000909549049_1037361_1887882840_n.jpg
Old 02-13-2012, 09:37 AM
No not ok. lol. Flip the outer brackets to the top side. If that makes any sense.
Old 03-03-2012, 01:07 AM
Hmmmm.... I don't really understand. Can you translate that for me? Lol
Old 03-03-2012, 07:32 AM
The two brackets that clamp onto the tierod( closest to the wheels) loosen them and rotate them 180 degrees( to the topside of the tierod). Any better? Lol
Old 03-03-2012, 11:32 AM
This is what I'm looking at...
Old 03-03-2012, 12:08 PM
Feedback Score: 3 reviews
It almost looks like the main center bracket needs to go under the tie rod, not above.
Old 03-04-2012, 06:45 AM
Ok check it out. It appears that the brackets in the bottom pic are the culprit as I thought. Unbolt both of them from the tierod and the shock. Then you need to put the one from the passenger side to the driver side and vise-versa. Mount it to where it makes the shock parallel to the tierod. Make sense? :/
