Clunk in front end going over bumps - Ford Powerstroke Diesel Forum
Old 12-28-2011, 07:00 AM
Hey guys, I've recently started hearing clunk from the front end (you can feel it in the floor board) when I go over decent sized bumps like speed bumps, rail road tracks and quite a bit on dirt roads. It doesnt happen around turns or anything. But I notice it's actually louder when towing. I thought it may have something to do with a steering component but the truck doesn't bump steer at all. Have any of you guys had a similar issue?
Truck info:
08 F-350 SRW
50k miles
Thanks for the help.
Old 07-27-2012, 09:21 PM
I think my truck has the same issue. I find mine does it when I slow down or take off from a stop. Its almost a loud metallic click, sounds almost like a u joint but everything looks tight. I have also noticed that my vacuum is turning on every 20mins. Could it be something to do with ESOF hubs?
Old 07-28-2012, 11:29 AM
Mine has been clunking on bumps so I started to check everything on the front end and my passenger u-joint is worn out and moving. Hope this helps
Old 07-28-2012, 11:32 AM
my 2000 350 did that and it was the ball joints, the lowers were really really bad as in when I went to get them out it fell apart!!
Old 09-12-2012, 07:09 AM
I had the same clunk.
Its ended up being the tierods. the lower bar had so much play in it that it was bouncing up and down on bumps
Old 09-12-2012, 07:20 AM
Really? How many miles did you have on your truck at the time?
Old 09-12-2012, 03:24 PM
my bro had the same noise on his 04 2fiddy. right outer tie rod fixed it.
Old 09-12-2012, 03:37 PM
Mostly ball ball joints.
