No 4wd low
Had to put my 08 in 4wd this weekend and only had 4wd high. The light for low never lit up and it wouldn't go into low. The high worked fine. Any ideas?
How did you go about shifting into 4lo?
Locked the hubs and turned the switch on the dash.
Gotta put the transmission in Neutral as well
Ok, never have used it but it will still go into high range w/o being in neutral?
Yes you dont have to shift to neutral to go into high range
Yep - The way mine works is I can go into 4-Hi while rolling. 4-low I need to be stopped, trans in neutral, foot on the brake.
Never would a thunk it, thanks I 'll give it a try.
