HELP! 2010 F 350 6.4 srw rear suspension problem - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-06-2011, 05:29 PM Thread Starter
Okay I have a problem with my truck and I took it to my dealer and they cant even figure it out so maybe someone has incountered something similar. When I drive over a pot hole or rounded curb like at the end of a driveway at about 10-20mph and my left rear tire hits and the suspension compresses and right when its rebounding it makes a hollow thud type of noise which is pretty loud almost like something hittting the under side of the bed. When it makes this noise I can also feel it in my feet. I had them look at the rear suspension but they said it all looks good . Anyone have any ideas
SHOWUUP1000RR is offline
post #2 of 7 Old 01-18-2011, 04:38 PM
colfaxent's Avatar
I have the same noise in my 09 srw CC , let me know what you find. JIM
2009 F350 Crew Cab
H&S Black Maxx Tuner
S&B Intake
2010 Cameo 36FWS 5TH Wheel
Hellwig Sway Bar
MBRP Cold Side Pipe
Closed system CCV mod
5160 Bilstiens x4
Icon 2.5 Front springs
PMF Floating Traction blocks and bars.
PMF Dual Steering Stabilizer
colfaxent is offline
post #3 of 7 Old 01-18-2011, 04:59 PM
storkerlovr's Avatar
and they can figure out what it is??? sounds like a shock or shackle is broken or something like that.....seems like an easy find
95 reg cab 4X4 STROKER
< trade for 5 speed???
new E40D
Autometer gauges
Gearhead tunes
EBP actuator deleted but not gutted
Push button start
TC lock up switch
DIY with 6637
3.5in DP
5in MBRP
315/75/16 M/T ATZ
3:55
smoked lights
herculiner
10inch PRO JL
20%tint
screw all this I just want a 6.4!!!!!!!!!!!!!!
wish list;
5 speed swap
stage 2 injectors
D66
"there may be snow on the mountain but that doesnt mean theirs no fire downstairs
storkerlovr is offline
post #4 of 7 Old 01-18-2011, 05:30 PM
colfaxent's Avatar
Not at all that evident, feel under driver feet and is intermittent.
2009 F350 Crew Cab
S&B Intake
Hellwig Sway Bar
MBRP Cold Side Pipe
5160 Bilstiens x4
post #5 of 7 Old 01-20-2011, 09:26 AM Thread Starter
Also i noticed that when i have weight in the back it occures more often. Have you taken it in and had them look at it yet??
post #6 of 7 Old 01-28-2011, 10:52 PM
scottylov's Avatar
I Had the same problem on my 09 f350 srw. brought it in and had it for 3 full days. They found a bolt that holds the cab on not set right. they said it was tight but was not in proper way. Now, I thought they were blowing smoke, but they were not. problem solved. They fixed it. I also felt the thump on my floor board while in a turn, like the drive way. I this helps!
2009 F350 Lariat Loaded LWB 4X4.
4.5 CST lift
KMC XD Series Spy
H&S Mini Maxx
Diamond Eye DPF/Cat Delete
AFE Stage II Intake
scottylov is offline
post #7 of 7 Old 02-17-2011, 08:00 PM
davesz06's Avatar
Superduty Thump
I had the same thing going on with mine and took it in to the diesel shop at my local ford dealer. They found the drive shaft slid was not greased from the factory. Your drive shaft is two piece and it needs to be greased where it slids. If not it will bind when try to go in and out!This may not be your problem but its worth a look see!:
davesz06 is offline
