08 Leveling Kit problems - Ford Powerstroke Diesel Forum
Old 07-26-2010, 03:54 PM
Now I'm Strokin6.4Liters
Feedback Score: 8 reviews
I just recently put a leveling kit on my 08 and it is pulling to the right even after alignment. And i mean it is so bad that I have to hold the top of the wheel at about the 11 oclock position. The kit is 2.5'' leveling spacers with blocks in the back and 5100s all the way around. What do I need to fix this? Is it a trac bar drop bracket or an adjustable trac bar?
Old 07-26-2010, 07:15 PM
Anyone?????
Old 07-26-2010, 07:21 PM
Feedback Score: 5 reviews
thats really odd, did it pull like this before the alignment?
Old 07-26-2010, 07:26 PM
No I could let go of the wheel and it rode straight
Old 07-26-2010, 07:28 PM
so this happend 100% after the alignment?? IF so take that thing right back..
Old 07-26-2010, 07:33 PM
this happened after the leveling kit was put on and aligned. I can't really take it back because they did it at the ford dealership in huntsville, al where I bought the truck and i'm in northeast tn which is about a five hour drive.
Old 07-26-2010, 07:53 PM
Hard pull
I personally don't believe you will need a adjustable trac bar or drop down track bar with just 2.5 inches. I believe the issue is with your alignment and did they change the eccentric cams by chance?
Old 07-26-2010, 07:59 PM
I doubt it. What are eccentric cams?
Old 07-27-2010, 03:46 AM
If you call the dealer that did the alignment and explain your situation, they may suggest you take it to a local dealer and they will foot the bill, if it is an alignment problem.
