squealing when braking and turning left ? - Ford Powerstroke Diesel Forum
Old 04-10-2010, 01:28 PM
I thought it was the brake pads, so I changed them and had the rotors turned. The noise is still there, sounds just like when u brake extremely hard and skid on the road and you hear that squealing of the rubber against the pavement.
for me it happens when I brake normally, from faint to loud depending on how much pressure I use, and sometimes when turning only left even without braking,
any suggestions on what to tackle next?
thanks
Old 04-10-2010, 02:18 PM
Wheel bearings maybe?
Old 04-10-2010, 02:21 PM
squealing would still be pads. what kind of pads did you put on? you need at least ceramics on these heavy trucks. metallic and semi metallic will still squeak when new on a heavy truck. wheel bearings is more of a howl, but considering your symptoms try replacing them
Old 04-11-2010, 04:27 AM
If it does it turning even without the brakes on you might want to check out your power steering fluid. If it is low or the pump is getting weak, it will squeel.
Old 04-11-2010, 08:13 AM
good call. i forgot about that one
