- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Bds carrier bearing drop looks good
Well been playing around the last few months with pion angles and drive shaft angles. Had a vibe at start been unable to fix it. So before I drop 1000 on a cv drive shaft thought I take a 50.00 gamble and it looks good
. Just a little info that may help somebody out with the shutter. |
| Sponsored Links |
Yes I even found the tsb on line from ford measured all my angles. One good point I was told from Jesse at high angle drive lines is he told me no matter what drive shft I go with in a two piece that my rear shaft needs to be 2* less then my pinon. so my pinon is at 9*-10* and now my rear shaft is at 7*-8*. I didn't measure my frist section but I know its more then 13* but if you want to know let me know and I'll get it over the weekend. Another thing dinone I think thats his name has a one piece and told me to call high angle drive line and his truck is 08 but Jesse told me he has not made a 1piece for 08 cc shortbed in at least 8 years. I dodn't know but try to get your rear section of the drive shaft 2* less then your pinon
Thank you for posting those numbers (and crawling under there in the rain)! I think I'm reading this right, but don't fully understand how you have some of these numbers. Are they the angle through the ujoint or the angle of the part in relation to the ground? You have to subtract from one side of a ujoint to the other, to get that joints angle. It's not the actual tube angles that you want, in the end. For example, tcase joint (which is hard because you have to get the angle finder on the tcase flange), measure the flange, then measure the forward shaft, and subtract to get the ujoint angle at the tcase. (So if your tcase flange is down at 6*, and the driveshaft is down at 10*, then the tcase angle is 4*). Then for the center (the easiest angle to find), you measure the rear shaft and subtract the forward shaft from it. Finally for the pinion joint, measure the rear shaft and subtract the pinion flange angle. Using that method, I think I'm somewhere around 4.5* downward at tcase, 3* downward at center, & 2* UP at the pinion joint. Are you saying that the rear shaft is only at 8.5-9* and the pinion is actually steeper at 10*? That would put your pinion at say 1-1.5* degree DOWN instead of the usual upward angle there? In relation to the ground, it sounds like you are saying the forward shaft is actually steeper than the rearward shaft... meaning... you dropped the carrier below the point of a straight shot. Is that correct? Sorry if I'm misunderstanding.
I am somewhat surprised that the pinion angle is negative (arches overhand instead of underhand), the first driveshaft is steeper than the second, the center joint bends underhand instead of over, and that actually works! Must have one hell of an angle at the t-case ujoint though. Wish I'd had the driveshaft made with a CV there as well, to handle that angle. Almost everything I've ever read says not to go over 4* or so through a ujoint for wear reasons, and the axle joint should always be positive so when you hit the gas and the axle wraps upward slightly, it puts that joint in a straight line. Can't argue with results though. Just kinda throws a wrench in everything written in the Dana/Spicer PDF's. If it ever stops raining here, I'm going to give this a shot! Thanks for all of the info! |
I read this and decided to try 2.75" drop with the extra shims I had laying around. I was at 2.25". I didn't measure any angles with the new drop and can't remember what they were before. I did have slight take off vibes and a light vibe at around 25 mph. With the 2.75" drop I have virtually no take off vibe and no vibe at 25 mph. I only got it up to highway speed for a bit but seems like there may be a slight vibration when I let off the throttle about 65 mph. Once I get out of town and on the interstate I will report more.
| Sponsored Links |
