Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Drivetrain Problems
Old 09-23-2009, 05:59 PM
pierre3737 pierre3737 is offline
Are brake rotors warranty on 08
Went to dealer today for a pulsating brake pedal, have 2 seized calipers but he says that the rear rotors are also warped and the front ones have rusted out. No kidding the calipers didn't work, I think the remaining rotors warped because of the extra heat caused by two wheels not braking.
What is under warranty, he days pads and rotors are not covered but calipers are.
Truck has 30000 miles
Thanks
Old 09-23-2009, 06:03 PM
TwinTurboStroker TwinTurboStroker is offline
Now, on to the race truck
Thanks
Yeah normally pad and rotors are not covered because they fall under the normal wear and tear. Unless they fail in short amount of time like a couple thousand miles, if you got to pay for them anyways look into some cross drilled and slotted rotors to help with the warping next time
Old 09-24-2009, 07:16 AM
ZeroOne ZeroOne is offline
Thats annoying.... clearly the rears are over-worked / warped for the same reason the fronts are rusty and under-used. If they admit the calipers were seized, how much more is it to realize the rears were ruined for the same reason? They can't admit that? I'd try to work with them (complain) even though pads/rotors are not warranty items.
