Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Drivetrain Problems
  #11 (permalink)
Old 07-17-2009, 06:39 PM
DSL_PWR DSL_PWR is offline
Originally Posted by avancamp View Post
is your wheel bearings in good shape?
Yes, truck only has 9500 miles on it, weekend driver only, used to tow. That is about it. Going in tomorrow.
Went to drop it off today but was told to bring it back tomorrow.
Stopped to look at two nice trucks both F-450's, one 2010 and one 2009. The prices on the 2010 went up slightly.
Might end up with a new one... hmm... decisions.. Gray or white...haha
  #12 (permalink)
Old 07-18-2009, 09:30 PM
Tony V Tony V is offline
Sweet Diesel Smell
White all the way!!!
  #13 (permalink)
Old 07-23-2009, 06:53 AM
Hags Hags is offline
So...... whats the noise?
  #14 (permalink)
Old 07-23-2009, 03:28 PM
Dealer could not duplicate.
So we wait...
  #15 (permalink)
Old 07-24-2009, 05:54 AM
jason1168tx jason1168tx is offline
I know you said your cab has not been off.....but the noise you describe sounds just like the noise I had after the cab had been re-installed. If you haven't already checked them, make sure all of your cab mount bolts are tight. The weld had broken loose on the nut on the left front of mine and the bolt would not tighten.
  #16 (permalink)
Old 07-24-2009, 06:40 AM
I will check them out but we are focused on suspension issues.
  #17 (permalink)
Old 09-01-2009, 12:53 PM
Ok well finally put the truck back in the shop and there is no front end issues with regards to suspension, brakes, springs, etc. Nothing was loose, body mounts all tight and sway bars are ok. The only thing they did find was the bump stops seemed to be rubbing into the frame and they were not sure why, could be the sound I hear when turning to the left and compressing the suspension. So going to pick it up shortly and we will see..
