Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 01-25-2007, 03:58 PM
scotty2280 scotty2280 is offline
egr problem
do the 04's have a problem with there egr's cuz ive already brought mine in for a p404 code about a month and a half ago and now the code is back. they only cleaned it last time. i guess im wondering if there is a better aftermarket one or will i just keep having to bring it in a pay the 100 deductible. or do i just have to clean it myself or ?????? any help would be nice
Old 01-25-2007, 04:20 PM
stump0331 stump0331 is offline
SNAFUSTUMP‹^›‹(•¿•)›‹^›
Tournaments Won: 1
try cleaning it yurself this time and if that dont get it you might want to look into getting another
Old 01-26-2007, 03:11 AM
Keith T Keith T is offline
The other alternative is get a SCT Xcal2 and have the EGR turned off in the PCM. Just remember to return the truck to stock before taling to the dealer for service. Keith
Old 01-26-2007, 04:19 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
there are other components that can cause a p0404 code beside the egr itself, ebp sensor and turbo sticking can also cause this concern , if it hasnt been long since repair id take it back and complain
Old 01-26-2007, 04:21 AM
oh yeah ,just because they cleaned it doesnt mean it stil an be sicking and sil be an egr problem ,try and get tem to replace it they can do that also if the valve is bad
Old 01-26-2007, 05:54 AM
WOOL-PULLER WOOL-PULLER is offline
does the truck sound different at any time with the EGR turned off?
Old 01-26-2007, 08:12 AM
My 04 sounds different at idle with the EGR turned off. I can't describe it but it is different. Keith
Old 01-26-2007, 12:49 PM
no, i dont know what it sounds like with it turned off, i should have said that i have a hyperpac and theres no option to turn it off. i just herd that the 04's had problems with this. its runing fine now but the when i got my hyperpac thats when i noticed the code and it went for about 2 months before it started to burn that white smoke and have no throttle responce.
Old 03-25-2007, 06:03 PM
dereku dereku is offline
Send a message via AIM to dereku
just dissconnect it, i did and got a few extra pounds of boost around 60mph and a huge drop in EGTs i never see over 1100 anymore
Old 04-10-2007, 05:58 PM
NavyCPO NavyCPO is offline
I unplugged mine..Everything works great..Put a glad zip lock bag on it with zip tie..Been that way for a year..I plug it back in when i go to dealer for service..( no codes or lights)
