Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 01-21-2007, 06:03 PM
trackmagic trackmagic is offline
Throwing code and runs horrible.
My truck is throwing the code P2285 ( Injector Control Pressure Sensor Circuit Low)
Has anyone ever had this code? Any ideas on how to fix it?
The truck needs help starting every morning. (Start it and give it gas for about 30 secs until it idles). White smoke comes out when I do this but goes away after a few secs. It will start fine every time except for the first time in the morning.
Old 01-21-2007, 06:28 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
where you from have you tried to plug in the truck at all
Old 01-21-2007, 06:58 PM
Yes, and it gets better but still doesnt start perfectly.
Im not worried that much about the starting, more that code. I just added in the starting problem in case it helped diagnose the problem.
Old 01-22-2007, 06:07 AM
PowerItUp PowerItUp is offline
I had the code p2285 a few months ago. Turned out to be the ICP sensor needed to be replaced under warranty due to leaking oil contaminating the sensor and wires. On my '03 the sensor is towards the rear and in a tough spot (PITA). Better have it checked as it will lead to a no start situation.
Old 01-22-2007, 06:17 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
sounds like you have two problems ,p2285 ,replace icp sensor and conector to make right ,and sounds like you ave a couple injectors giving you a cold start rough runing concern ,get the icp sensor taken care of and do the latest calibration update and see if that dont fix it
