NO START
I have a 04 F-350 with the 6.0. I pulled into a grocery store and went inside. Came back out and the truck would not start. It would turn over very easily. Never had a sign before any thing was wrong. Plenty of power. Can someone give me some insight of what this might be. Haven't changed the fuel filter since I have bought the truck. Any insight would be of great appreciation. Don't understand, one minute everything is good and 5 minutes later truck won't start.
Thanks Nate |
high pressure oil pump maybe
How many miles is on it? And also have you had a chance to get any codes pulled yet? Could be a crank sensor or what scuffy828 said. Im working on one right know with the same problem it hpop orings blown. This one has no codes.
I have 300,000 miles on it. The only thing that I have done to the engine, was replace the oil cooler. I have not pulled any codes. Do you know how the oil pump could keep it from starting??
if it doesn't make enough pressure it won't let the motor start
Where exactly is the HPOP located and how hard is it to change the o-rings?
