6.0 whining noise - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-06-2009, 05:54 PM Thread Starter
sgriffin's Avatar
6.0 whining noise
I was pulling a load this weekend and when the RPM's reach around 2200, I get a whining noise from under the hood, it last for a short time then in about 10 seconds it whines again. This only happens over the 2200 mark. It is like it only happens when there is a load on it. At low RPM's the truck seems to run fine. I took it to a dealer and they mentioned that the Turbo may need to be cleaned, He ran all test w/ computer and the truck passed all test. I just need to know if someone has had something similar happen and if it is a DYS fix or a dealer/mechanic fix.
sgriffin is offline
post #2 of 3 Old 04-06-2009, 05:58 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
Was it your fan clutch engaging?
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #3 of 3 Old 04-06-2009, 06:08 PM Thread Starter
sgriffin's Avatar
Would that cause it to loose power? when it does it I have to back off of it and get it back down below 2200 rpm to get it to pull. I could only get about 65 mph out of it. It seems to run fine at low rpms
sgriffin is offline
