EGR Block off - Ford Powerstroke Diesel Forum
Old 04-05-2009, 03:17 PM
EGR Block off
i just got my 06' 6.0 and am really looking to block off the egr before i get soot build up because i heard that can get bad quick i was just wondering what would be the best thing to do just to maintain it or block it off, if so whats the cheapest way to do so. thank you.
Old 04-06-2009, 05:49 PM
i bought a new up pipe that did not have the scoop and came with a plate to block it off. if i were to do it again i would probably just take the old up pipe and take the scoop out of it and weld a plate in it. thats just my opinion...
Old 04-06-2009, 07:12 PM
It all depends if you wanna keep a stock apearance for warranty issues??
Old 05-03-2009, 05:59 PM
i am debating on which egr option to go with also. and if i get it which one is do it yourself or much in a shop do they usually run?
Old 05-03-2009, 08:09 PM
thats the clincher
Old 05-03-2009, 08:33 PM
pm 03f250 he will hook you up on a kit.
Old 05-04-2009, 08:14 AM
cheapest if you have a welder is to weld freeze plugs in each end of the EGR cooler, and with the up pipe put it in a vise and with a steel horse shoe stake or pipe, mash the scoop flat inside the up pipe. Then reassemble and it all loooks like its there and cost you about $1.75 for the plugs and maybe $20 in new gaskets the EGR cooler connections, obviously more if you decide to use new intake manifold gaskets.
