OBD II port fuse - Ford Powerstroke Diesel Forum
Old 04-02-2009, 05:10 AM
Almostdunfukinwidit
OBD II port fuse
What else besides the OBDII port and cig lighter does fuse 12 control on the truck? Its blown 2 times in two days When I tried to change a tune
Old 04-02-2009, 05:52 AM
I don't know. Does it blow when the SCT gets plugged in? Man i would really worry if that is the case. You do not want to short the SCT or PCM. If it is fine until you plug in the SCT it is most likely the SCT.
Old 04-02-2009, 05:54 AM
Almostdunfukinwidit
It was blown before i plugged the SCT in both times. It wasnt this morning. IM hoping it was a fluke
Old 04-03-2009, 09:08 AM
Fuse 12 controls the dlc, cig lighter, and the horn.
Old 04-03-2009, 09:09 AM
Almostdunfukinwidit
Hasnt blown since
Old 04-03-2009, 09:11 AM
Sounds good, hope you dont have anymore troubles, but if it blows again check out the horn too!
