please help asap
i changes my fuel filters today. after i primed the truck over and over agian. its starts i pull it out of my garage letting it idle for a little. then dies cant get it to start all fuses are ok. turns over. acts like its not getting fuel. i even took the top fuel filter off and put gas in it try to get it going to go. fuel pump seems that it is running b/c i can hear it. also tried loosining the caps and tighting them to see if it was too tight and crushed the gasket. i dont know. please and thank you.
please help the truck is a 2005 f250 superduty 6.0 |
Is the drain on the fuel bowl still open?
Oops, its a 6.0. not sure if its the same or not
welcome to the org anyway. |
it is a diesel i pluged the drain plug back up no leeks anywere
make sure the cap on the lower filter is tight , seen them suck air before
still no it. it is tight
Try cycling the key on and off several times just to be sure the air is purged.
did that done it so much my battery is dead i lost my jumper cables now i have to wait till morning
still dont know what it is
Caps on the filters are tight? Orings seated? filters installed correctly? Double check all of the above. If it ran fine before you changed the filters, its either one of the above or you got the wrong filters
