loosing coolant - Ford Powerstroke Diesel Forum
Old 03-27-2009, 02:18 AM
loosing coolant
Hi guys,
I noticed latelly that I am loosing coolant on my truck. There is no puking, no signs of anything and I dont tow etc.
Head gasket problems?
thanks
Magnus
Old 03-27-2009, 02:23 AM
check degas bottle and cap. may need to replace cap FIRST. check bottle for cracks. there was a bulletin on it a ways back on it
Old 03-27-2009, 02:25 AM
I see no leaks or anything under the truck, it stood for a week the other day, and nothing under it, so there should be no leak?
Old 03-27-2009, 02:34 AM
Is your truck tuned at all? People might want to know to help you out
Old 03-27-2009, 02:43 AM
lifetime member
Old 03-27-2009, 03:44 AM
hi, nope, no tune, stock as stock can be
Old 03-27-2009, 05:15 AM
Totally off subject, nice Prodigy quote Magnus
Old 03-27-2009, 07:49 AM
hehe thanks!
Old 03-30-2009, 04:36 PM
I would suspect an egr cooler concern on this long before thinking head gaskets. Keep in mind that most times a head gasket results in coolant venting from the degas bottle at WOT. egr cooler Will most often leak into the intake and get combusted, if its a small leak you wont see any white smoke or coolant from the exhaust. hope this helps a bit. if possible remove the egr valve and look for any sign of coolant on the valve.
Old 03-31-2009, 04:52 AM
thank you!
