6.0 engine and front end problem?
Got two questions......Sometimes while im driving on the interstate ill be maintaining 70-75mph and i hear my turbo make a sound like it is reving itself but i am not tapping the gas pedal. Kinda hard to understand cause I dont really know how to explain the noise but any input will be helpful...and 2nd lately when I hit a bump or the weight in the truck shifts Ive been hearing a click noise. It only occurs when there is weight transfer or i hit a bump. It appears to be coming from the front end under the floorboard on the drivers or passenger side. Yesterday I stood on the running board and shook the truck and it made the noise but I am unable to determine what the noise is.
Anything will be great before I have to take it to Ford to look at it. thanks, KC |
Does it run fine (no smoke, no power loss, no cel)? Check the ball joints, and the stabilizer bar bushings, also if your truck is 4x4 check the front u-joints.
the truck seems to run fine sometimes it runs a little rough but no smoke or anything. So how do i check the joints and all that and yes the truck is a 4x4? Im not the best when it comes to repairs
Jack up the front axle as close to the ball joint as possible, then pry up and down on the bottom of the tire heres bsome random picture i found via google for testing ball joints, look for play. http://www.carquestchassistraining.c...ction_0002.jpg
To check the stabilizer bar bushings, look for shiny spots on the bar near the bushings, grab the bar and shake it too. If its shiny or moves alot replace the bussings. |
As far as the running issue, if it sounds like a whistle noise, you may have pressure escaping the degas bottle cap. That could be from a bad egr cooler or headgaskets. Any puking?
u lost me...lol puking as in ? i was reading up is ive had the vehicle since 04 is there a way to clean the turbo or anything that might help?
Coolant pucking out of degas bottle. Yes there is a unison ring and vanes in the turbo that gets all sooted up. But i dont think thats your problem, based off of your description of the problem.
thanx please do I am very curious....
