Put truck in gear and it died!!
I've been on storm work the past few weeks, and when I got home Wednesday night, I went out and fired my 06 F350 Powerstroke up and it started like normal. Didn't start hard, no smoke, nothing. I let it idle for about 5 minutes, and went out and was going to leave. Put it in gear and as soon as I put it in gear it died. Didn't lug down or anything, just died. I checked my Egr valve, conections on the IPR, and all fuses, nothing seems bad. Any directions to go. Check engine light is not on, nor do I have any stored codes.
Thanks in advance. |
Did you try it again.
possibly the cam position sensor. that happend to me before ran fine and in gear or touch the gas it woud die.
I've tried starting it numerous times since it died, and it won't even start now. I just pulled the connector off of the cam position sensor, and it's seems to have oil in the plug in itself. Going to clean the connector, and then try again. Just wish that they would have made the sensor as easy to get to as the 7.3 sensor is..
GOOD LUCK TO YA!
same happened to me and it was the ipr valve also wile i was deep in the engine i changed the hpop quick conect fitting for the new version runs like a champ!
