Now it will not start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-04-2009, 02:46 PM Thread Starter
This mourning Iwent outside to start my 99' F250 super duty (241k miles). Like every mourning I waited for the glows to time out and started it. Started right up as usual. Went back inside to let warm up. 5 minutes later I returned to find it had stalled. That NEVER happened before. I tryed it again and it started right up. Then it shut off after apprx. 5 seconds. Now it wont even fire. I noticed the "wait to start" light does not light up. To make things more difficult, I was in a head on crash with it (dontwish that on any Ford), I repaired it myself, Hood, ds fender, grill/ bumper, inter support, etc. The computer inside the ds fender was untouched in the crash, but under the ds battery was a module that was damaged. It had about 20 fine electronic pins that pluged into it. The bottom of the module and the connector had slight damage. After inspecting it looked good. I siliconed the damage. I ran the truck 5 weeks after the crash and about 2 weeks after the repair. All fuses are good. Any suggestions?
electrifierus is offline
post #2 of 5 Old 03-04-2009, 02:48 PM
ADMIN AND TECH
SCUFFY828's Avatar
you probably blew the fuse to the fuel heater which is also pcm power , no wait to start light means no pcm power , unplug the two wire white connector on the backside of the fuel filter housing and replace necesary fuse
ITS STOCK
SCUFFY828 is offline
post #3 of 5 Old 03-05-2009, 02:22 PM Thread Starter
A day later. I found the blown fuse. Unplugged the "green" two wire connector behind the fuel filter, and it still blows the fuse with and without the connector plugged in.
post #4 of 5 Old 03-06-2009, 04:48 AM
ADMIN AND TECH
SCUFFY828's Avatar
you unpluged the waste gate solenoid , you have to unplug the white 2 wire connector on the back side of the filter housing , the connector you unpluged is mounted on the intake , this connector you have to look down lower
ITS STOCK
post #5 of 5 Old 03-06-2009, 03:40 PM Thread Starter
Yep, my bad, that was it, need a new fuel bowl heater. Been working way to many hours lately. Thanx for the good advice. This is the first time it happened to me. My work fleet consists of a '96, '97, 2 - '99s, and an 01, all with 7.3 power strokes. also have a Cat and a Detroit in my bigger trucks.
Scuffy 828 rocks!!!!
