Oil Leak from Drivers Side - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-01-2009, 12:03 PM Thread Starter
mad103's Avatar
I noticed an oil leak in my truck a few days ago. Looking at my driveway it looks like its been leaking for a while (several oil spots). It is a red oil from the drivers and I have looked under the hood to see if I can track down the problem. Any ideas? Could it be the powersteering? I did a recent oil change but that looks to be fine and the oil is that is more on the black side. Help
2005 Ford F-250 Black/Brown Lariat 4-door/shortbed
8" Fabtech Lift
20" Rims and 38" Tires
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #2 of 6 Old 03-01-2009, 12:16 PM
Abrannan19's Avatar
Feedback Score: 5 reviews
if its red thats transmission fluid..
if its balck i would look at the glowplugs right above the driver side manifold..you may see some oil around there..
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #3 of 6 Old 03-01-2009, 12:26 PM Thread Starter
mad103's Avatar
you see i thought it would be tranny fluid but for some reason I think the drip is coming from above near the steering column area. At least that is where I noticed a little bit of some drip. It sucks because its hard to look at it right now in the rain.
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #4 of 6 Old 03-01-2009, 12:31 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
I cant think of any other fluid that is red colored!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #5 of 6 Old 03-01-2009, 04:07 PM Thread Starter
mad103's Avatar
I did think it was the tranny fluid and the tranny does leak a bit but most is coming from up top from behind the airintake/battery area. I noticed because the tubing is oiled from up there. Its a brownish/redish fluid
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #6 of 6 Old 03-02-2009, 11:22 AM Thread Starter
mad103's Avatar
If it is the tranny, what would be the cause of it and how could I go about correcting the problem?
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
