Truck wont start?
I walked out to my truck this morning and it was about 50 degrees outside and I got in my truck and let the glow plugs cycle and cranked the engine over and it just cranked for about 15 seconds. I turned the key off and tried to start it agian and it fired right up? It has never done this before except this one time. Do I have a High Pressure Oil pump going or is do you think it was just a freak accident and it shouldn't concern me. No check engine light but here are the codes that were stored P0263 P0341 P0403 P0405 P2287.
DONT THINK IT WOULD BE A PUMP. MORE THEN LIKELY A HIGH PSI OL LEAK. PROBOBLY A DUMMY PLUG IN THE RAIL OR AN STC FITTING AT THE PUMP. AIR CHECKING THE SYSTEM WOULD BE A GOOD IDEA. BUT I WOULD MONITOR THE PSI ON A SCANNER FIRST
im tinking the ipr valve
that is really common to. if the screen is damaged at all replace it
