EXHAUST IN CAB - Ford Powerstroke Diesel Forum
Old 02-21-2009, 02:31 PM
EXHAUST IN CAB
After a cold snap (working in Ohio, 6 degrees...) I started getting exhaust fumes through my heater fan. (I had had the egr cooler replaced about 10k back, under warranty-and was driving when it began to overheat- I would stop, it would cool, made it to where I could check antifreeze-none-drained about 2 gallons added antifreeze). Since about 2 weeks after, began to get exhaust in the cab... is there a valve, a ???? , something that would give me a clue-my work schedule is heavy, do not want to sit for a day..
(new 6.4 in a week or so!!)
Old 02-21-2009, 04:15 PM
It's your Y-pipe the flex part of the pipes like to break.
Old 02-21-2009, 04:56 PM
Thanks, appreciate the quick help...
Old 02-22-2009, 07:32 AM
International Harvester
Is it exhaust fumes or fuel smell? I had fuel smell in my cab when the heat was on, turned out to be a bad o-ring on the engine mounted fuel filter cap.
Old 02-22-2009, 07:40 AM
yea thats the flex on the y pipe. dads did the same thing
Old 02-22-2009, 08:20 AM
If you start to see black film starting to build up on the inside of your front window, then its your y-pipe
Old 02-22-2009, 08:35 AM
you got the y pipe back there and you got your uppipe going to the cooler, maybe the flex broke then they were replacing the cooler or at least started it on its breaking point.
look back on the firewall to see if you have any soot back there, ive seen y pipe blow up to where they actually hit the firewall and it makes an awful noise and smells like crap inside the cab. you can get back there with a flash light, from under the truck or on the top and see if you see anything cracked
Old 02-22-2009, 08:38 AM
I also have exhaust smell in the cab with the heater on. It only started after i modified the up pipe and blocked the exhaust end of the egr cooler. Does not do it with th a/c on though. I looked for leak with my hand and visualy when engine is cold and out side temp is around 30 f and no leak found. Any help would be apreciated.
Old 02-22-2009, 11:56 AM
No black film yet, having destroyed a LOT of brain cells in the past, I keep the cab well ventilated to allow the survivors a chance.... (now that I think about it, utilizing the surviving core group.. the windshield does look like my wife has smoked (in the cab...)
Old 02-22-2009, 01:59 PM
I have no black film yet. And it is not alot of fumes i can just faintly smell it, Only at a stop light.
