Air Conditioning - Ford Powerstroke Diesel Forum
Old 02-21-2009, 09:28 AM
Air Conditioning
Well my air doesn't work anymore. It will blow somewhat "cool" air but it really just makes it hotter in the cab. Any ideas?
Old 02-21-2009, 09:29 AM
try a recharge. if it stays in your good. if it leaks than it could be anything.
Old 02-21-2009, 09:41 AM
IU Hoosier Fan
WOW... you need ac now?? this time of year.... heck it is snowing right now
Old 02-21-2009, 09:43 AM
Yep Thats Alabama for you
Old 02-21-2009, 10:07 AM
Unapologetically American
Feedback Score: 4 reviews
Look at your compressor, where the shaft comes out. There is a seal there that will leak from time to time. If so, you will have to pull it out and replace the seal, and take it somewhere that will be able to pull a vacuum and recharge it. If its not leaking shot do a gas'n'go (charge it back up).
Old 02-21-2009, 10:14 AM
You to put gauges on it first before you try anything. That will tell you if your low on refrigerant or have an electrical/mechanical issue.
Old 02-21-2009, 11:18 AM
Have the pressure tested, mine quit working last year and it turned out that one of the hoses was rubbing on the engine and finally rubbed a hole in the hose.
Old 02-21-2009, 11:40 AM
If it aint a CAT itsa DOG
If it is leaking, i have seen guys put a dye in the system to help identify the leak.
