So my hpop blew out the plug, looks like the pump spun (happened while driving) But hey while I'm there, lets inspect the EGR cooler and oil cooler. EGR cooler clean as a whistle, Oil cooler had a little bit of slippery residue on the outbound side and just a tiny bit of something on the intake side at the bottom, not gritty and not much.
What are the flow specs for the coolant side on a 6.0 oil cooler? At the rad shop we used to have a flow bench but it seems the 6.0 is temperature spread based.
I was seeing oil temps staying within 5-15 degrees of coolant temp warmed up on the highway but usually less than 10 sustained.
I have the HPOP out, so removed the cooler, has the plastic screen down under so it must be original, I backflushed the cooler with a garden hose, there was a little discoloration right away and that cleared up. We're on city water 140 psi static and about 4 gpm I'd venture to guess. Flushed both directions with really no restriction in flow. I added a little oxalic acid solution to the cooler and rotated it all around for a few minutes, it turned brown, flushed and repeated four times last two times there wasn't any more discoloration or fizzing, added a hose nozzle to introduce air and bubbles into the flow. Some small flakes of rust maybe 1/4 inch square did come out during the whole process but overall it looks really clean.
Next is digging into the hpop to see if its indexed correctly.
