06 f250 w/ 118k miles. The a/c worked but not as great as it should when i purchased the truck and then i didn't use it over the winter and then had studs put in and tried to use it this summer and it just blows hot air when on max a/c.
Took it to a hobby shop to repair myself, so i took all the freon out and noticed the low pressure side schrader valve might have been leaking a little when i took the cap off. I couldn't get the orifice tube out but noticed sand on the tool when trying to remove the tube. Where should i start trouble shooting.
I've researched and can't find to much about this problem except to take the washer out of the compressor. But i'd rather not replace parts that don't need replacing.
Also when i would turn it to max a/c the compressor kicks on for less than a second and then off again. It cycles like this several times but doesn't ever stay on
Try changing the valve stem on the low side and recharge the system. Blow the low side out with a little air first though. Had a problem once like that. Hope this helps : )
replace the accumulater,it has come apart,the sand is the deccisent in it.also replace the orfice tube and blow out the lines with a proper solvent.Serious damage can happen when that sand gets to the compressor,the accumulater is the big can like thing on the side of the heater box,arent expensive,buy a new one,wouldnt trust a used one.Harvey
An if you can't get the orifice tube out, just replace the line. It is not that expensive, plus it sound like it captured debris from the accumulator.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
