Rough Cold Start - Ford Powerstroke Diesel Forum
Old 01-27-2009, 10:51 AM
Rough Cold Start
Hey Im new to this site and having a few problems with my truck. I have a '05 F-350 with and Edge programmer. Whenever I go to start my truck in the morning it starts up real rough. Sounds like the truck wants to die but still keeps going. After a bit it settles down and will idle normally. When I put it in drive it will sputter for about a mile and then it will stop. Sounds like an injector is missing, however after it warms up it runs and drives fine. Any help would be appreciated.
Old 01-27-2009, 12:22 PM
Same thing as my truck when I bought it 4 weeks ago, would start rough sputter for the first little bit, then would run fine. Also it would shake a little on the highway Cruise control set at 60-70mph. Put it to the floor and ran fine.
Result: #5 and #8 replaced by the dealer. You still have 100k warranty left? take it in.
Old 01-27-2009, 02:45 PM
I have 92K on it. Will the warranty cover it? I bought it used from the 2nd owner.
Old 01-27-2009, 05:08 PM
36K/ 3 year bumper to bumper, then I think 60K powertrain, and a 100k / $100 deductible Powerstroke warranty. For some reason, my injectors were "related to emissions" so it cost me nothing.
Like from the "40 y/o Virgin" - Use it before you loose it!!
Old 01-27-2009, 05:21 PM
Guess I need to take mine in as well. Same exact problem. Do I need to remove the Edge before taking it in?
Old 01-27-2009, 05:23 PM
Jon
Guest
Posts: n/a
Sounds like you need a reflash. I'm sure you will get some injectors out of it to.
Old 01-27-2009, 05:25 PM
Ok should i remove the Edge before I take it in and should I put my CAT back on because I took it off?
Old 01-27-2009, 05:27 PM
Jon
Guest
Posts: n/a
I wouldnt put the cat on. I usually unhook the edge though.
Old 01-27-2009, 05:36 PM
Ok thanks for all the help.
Old 01-27-2009, 06:27 PM
my 03 did the same thing,2 bad injectors.covered under 5yr 100,000 mile warr. only had 93,000miles but was 4 yrs and 9months old..lol
