I have a 2003 6.0 F250. Shortly after purchasing the truck we had the EGR cooler failure. I replaced the Oil cooler, EGR Delete, blue spring upgrade and other basic maitence.
Truck did well for a few weeks. It always had a cold starting issue. This led us to the latest event. The truck stalled and we towed it in. I performed a air test with the Hpop cover off, and confirmed a bad HPOP.
Installed a new ford HPOP, also found the IPC sensor was starting to leak oil and replaced it. After assembly the truck cranked for a while, and then fired up and ran fantastic for about 10 seconds. After 10 seconds it shut right off. No stumble, nothing, just killed over.
I hooked up the scan tool and found the following-
IPC 314 IPR % 15 FICM Voltage 48.5 FICM Sync NO and no rpm read out.
I've gone over and wiggled all the wires and did not make any affect to it- It appears somehow I've lost a connection, but I'm open to any suggestions.
