New Guy, changing the fuel filter on 6.0? - Ford Powerstroke Diesel Forum
Old 01-21-2009, 06:10 AM
I'm trying to change the fuel filter on my 04 F250. It has the 6.0, I have a Chiltons manual and it says I have to release the presure. I found the water seperator canister on the left frame rail in front of the gas tank. It says there a valve there. I don't see it, do I have to remove the cap on the water seperator?
Thanks, Kelly
Old 01-21-2009, 06:14 AM
its an allen key, you drain that. after that then pull the filter and change it, then up by the motor there is another filter, change that too
Old 01-21-2009, 06:16 AM
Bring On The Snow
Send a message via AIM to SuperDutyPSD6L
I have never drained the little hex key valve when I do my filter lol maybe thats why I get fuel everywhere when I pull it
Old 01-21-2009, 06:24 AM
I got two new filters, is one for the water seperater on the frame and one for on top of the motor?
Old 01-21-2009, 06:25 AM
Bring On The Snow
Yes the big one is for under neath on the rail and the small one is for up top on the engine.
Old 01-21-2009, 06:32 AM
Does anyone know what size socket the cover takes on the water sepeator on the fram rail? It looks like a 1 1/2" or so. I don't have one, will probably make one once I figure out the size.
Thanks, for all the help everyone.
Here is a link on how to change the fuel filters. It's very simple.
Changing 6.0 fuel filters
Old 01-21-2009, 06:59 AM
Send a message via AIM to jhaddox
its a 36mm...thats what you use for the oil filter too
if your talkin about the cap that covers the inline fuel filter
Old 01-21-2009, 07:03 AM
Send a message via AIM to FastFocus
subscribed, also what filters do you all recommend? oem motorcraft or what?
Old 01-21-2009, 07:24 AM
Motocraft forsure....their filters have a pattend and no one else can make em just like ford...they are gonna make the best ones that come out...all the others are just a little shorter, or thinner...so everything wont get filtered and some stuff can slip past on MOST filters besides motorcraft
