Brake Pedal Kickback - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-19-2009, 12:27 PM Thread Starter
Redneck47441's Avatar
Quoted: 2 Post(s)
On my father in laws 04 CC SB 4x4 when I hit the brakes for a split second it feels like the abs kicks on by the pedal kicking back a little. What I was wandering is if anybody else has or had this problem and what you did to fix it. I heard when your truck does this its usually your power steering pump.
Redneck47441 is offline
post #2 of 8 Old 01-19-2009, 03:44 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
The brakes are hydro boost. It uses the power steering pump to supply you with power brakes. If you stab the brakes real quick you will get a little kick back. Mine does that at least and it is the same year as your father in laws.
dhanna6powerstroke is offline
post #3 of 8 Old 01-19-2009, 03:45 PM
duct tape & zip ties
bigcountrysg's Avatar
Becareful with it, you may blow the hydro boost supply line from the powersteering pump.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #4 of 8 Old 01-19-2009, 07:25 PM Thread Starter
Quoted: 2 Post(s)
The truck hasn't always had this problem with the brakes thats just started recently but Ive always suspected something to be wrong with the powersteering because when going in a slight turn you can let go of the wheel and it will stay turn the steering always been a little stiff kind of like it has stiff valved dual stabilizers on small tires. Whats the best way I can flush the pump at home.
post #5 of 8 Old 01-21-2009, 12:42 AM Thread Starter
Quoted: 2 Post(s)
Bump!!!!!!
post #6 of 8 Old 01-21-2009, 11:52 AM
2003-07 trucks grabbing brakes, pedal kickback:
This may be caused by power steering fluid contamination in the hydroboost system. There is a procedure for installing a temporary filter between the power steering pump and cooler to clean the system. After the cleaning procedure is complete and no brake grabbing or excessive steering effort is felt, remove and discard the filter. If brake grabbing continues, replace the hydroboost unit. Filter P/N XC3Z-7B155-BA; TSB# 99-25-8, 7-11-10
SDLooksgood is offline
post #7 of 8 Old 01-22-2009, 11:12 AM Thread Starter
Quoted: 2 Post(s)
Do you know how to add that filter.
post #8 of 8 Old 01-23-2009, 09:41 AM
I'd say go to the dealer with the TSB number and ask them. A tech maybe willing to help.
