Ball Joints - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-19-2009, 01:18 PM Thread Starter
Rob
Rob's Avatar
Quoted: 2 Post(s)
Ball Joints
So how do you know when they are worn and need replaced??? any noticeable noises while driving?? also, is this a job that a shop MUST do???
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #2 of 9 Old 01-19-2009, 01:20 PM
fordpwrstroke7's Avatar
You'll get a knocking sound when moving. Jack up one wheel at a time and grab it on the top and bottom. Try to rock it/wiggle it back and forth. If they move, you need to replace them. If not, you're probably good to go. You can do it yourself if you have technical skills...and patience.
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #3 of 9 Old 01-19-2009, 01:25 PM
International Threat
Marty's Avatar
Add one thing to the above... have someone do that while YOU watch the end of the axles... see if the ball joints are moving or the wheel bearings.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #4 of 9 Old 01-19-2009, 01:25 PM Thread Starter
Rob
Rob's Avatar
Quoted: 2 Post(s)
do i need to jack it up at the frame???? i get this light knocking sound, but not sure where it is originating from... i notice it when i hit small bumps in the road.. most noticeable at low speeds....
at any time.
Rob is offline
post #5 of 9 Old 01-19-2009, 01:28 PM
You can do it at the axle. Also check your bushings on your sway bars, leaf springs (I didn't see if you had an 04 or older) and track bar. If your ball joints check out OK, try disconnecting each of the components listed above, one at a time, to isolate the problem.
2008 F-350 CCLB
post #6 of 9 Old 01-19-2009, 01:45 PM
The way I check is to jack the truck up under the front axle like said before but I use a pry bar at the ball joints to see if there is any play in them. If you can get play by hand then they are really shot. Yes you can change them yourself. The hardest part is getting the old ones off. The most important thing to do is to measure the length of the tie rod you take off from center of joint to center of joint and and put the new one together at the exact same length. When I put mine together it still tracks straight as an arrow and never even bothered to get an alignment.
99' Powerstroke is offline
post #7 of 9 Old 01-19-2009, 01:58 PM Thread Starter
Rob
Rob's Avatar
Quoted: 2 Post(s)
ill have to get under there and check them out.. hopefully they arent bad... maybe i got something else loose or makin the noise..
at any time.
Rob is offline
post #8 of 9 Old 01-19-2009, 02:15 PM
A common problem that makes that clunk sound going over bumps is the sway bar end links have bad bushings. Not sure if you have the end links in your 04' though.
post #9 of 9 Old 01-19-2009, 02:22 PM
willholl79's Avatar
+1 on jacking up and checking for play. +1 for doing it yourself. There is a good write-up with pics on here somewhere.
2005 F-350 CC LB 4x4 XL 6.0
SCT
4" Turbo back exhaust
03 turbo
Studs
Coolant Filter
Warren Stock+ injectors
1996 F-250 ECLB 4x4 XLT 7.3 Auto
1993 F350 CCLB 4x4 5spd 7.3 NA
willholl79 is offline
