So this may sound like a broken record but i have had an EXTENSIVE amount of work done to my truck, and I'm still getting white smoke at idol and when i first hit the gas pedal from take off, and still losing coolant in degas bottle. I have done the following items to my truck in the past month and a half.
ARP Head Studs
BPD EGR Cooler
BPD Heavy duty oil cooler
OEM Head Gasket
Resurfaced Heads
New Injector seals
6.4 Banjo Bolts
Serviced Turbo
The dealer is going to replace the turbo at this point hoping to solve the problem, there saying if that doesn't fix this problem then its due my truck being straight piped and no back pressure to the turbo. My truck never smoked going into the dealer all that was happening is losing coolant in the degas bottle. Any advice please on what the issue would be??????
ARP Head Studs
BPD EGR Cooler
OEM Head Gasket
Resurfaced Heads
New Injector seals
6.4 Banjo Bolts
Serviced Turbo
