Engine Codes - Ford Powerstroke Diesel Forum
Old 01-14-2009, 07:50 AM
Engine Codes
So I'm messing around with my sct livewire today wanted to check all the settings and stuff so saw something about codes so i checked em out there was 4 on there
P0603 Powertrain Control Module Keep Alive Memory (KAM) Error
P0670 Glow Plug Module Control Circuit
p0683 Glow Plug Module Control Circuit
p0000 N/a
Well the p0603 is this from the tunes?
So i reset them and drove the truck around after retuning home there was only 1 code on P0670 Every time i try and start my truck it take about 4 cranks and its up and running with no problem buddy of mine has a 05 f250 about same miles and his takes 1-2 cranks.
As of right now there is noting wrong with the truck that i can see there is no engine light on every thing seems to be working fine. Other then my glow plug control might be going out.
Old 01-14-2009, 08:15 AM
ADMIN AND TECH
ill agree with the module maybe goin out , if the truck is starting fine dont sweat it
Old 01-14-2009, 08:20 AM
Yeah not really sweating it just wanted to know if anyone else had this problem and stuff but thanks for the fast reply
Old 01-14-2009, 11:41 AM
Powerstroke Techie
By the codes listed, it sounds like your glow plug control module has failed. This would explain why it takes about 4 cranks to get the engine started cold. Replacement is just a matter of two 10mm nuts and two electrical connectors away, on your passenger side valve cover beside the ICP sensor.
Old 01-14-2009, 11:59 AM
Just called ford they told me the glow plug control module is about 220.00 + tax sound about right? I think it could wait another oil change before I fix it.
