help a/c not working - Ford Powerstroke Diesel Forum
Old 01-12-2009, 01:53 PM
well my a/c stopped working ...just blows warm air ......so i was wondering what i should look for ....any fuses, relays i should look at.....thanks for any help
Old 01-12-2009, 01:58 PM
check to see if your blend door is moving from warm to cool when you move your temp knob.
Old 01-12-2009, 02:03 PM
what the blend door?.......all the functions work from defrost to the vents at the feet .......and when i turn the temp up it does get hotter .....so thats working ......its just at coolest setting and on max ac it blows warm
Old 01-12-2009, 02:07 PM
pop your hood and see if the compressor is turning...
Old 01-12-2009, 02:12 PM
k ill go check
Old 01-12-2009, 02:28 PM
try bypassing the pressure switch to see if you lost the charge
Old 01-12-2009, 02:31 PM
mmmmm how do i do that
Old 01-12-2009, 02:32 PM
well i popped the hood turned the a/c on and the compressor keeps kicking on and off ........is that right
Old 01-12-2009, 02:37 PM
it sound like your low on freon go to parts store pick up a can of 134 an put it in it will take care of the problem and to double check tha the pressure sw is on the canester on the pass side use a wire and jump it if it run all the time that the trouble your low
Old 01-12-2009, 02:38 PM
IT depends on how long the cycling how long is the cycle if it is repeadly very quick you prob have lost a your R-134A charge and therefore have a leak in the system and will have to leak tested
