I just had everything done; studs, powermax, stock injectors, sct fitting, sandpipes and dummy plugs, new fan, oil cooler and egr delete, sct tuner and tunes from innovative. Over the weekend I pulled my 8500lb trailer to the sand dunes with no issues on the way there. On the way back I was hitting 235 coolant and 241 oil. Delta on flat ground were 12 degrees max. Everything was done by weeks ago. What might be my issue? Measuring everything with an edge insight cts.
New fan or fan clutch? I'd make sure that is plugged in and functioning properly. Next how old is the thermostat? Could be stuck closed. If it is old replace it. And then finally how old is your water pump? Any leaking coolant from the weep hole on the water pump?
New fan and fan clutch, new thermostat, new BPD water pump. I just had the entire truck done a week before my trip. Everything was clean. It was hitting high temps when climbing but I could not hear my fan ever kick on. Runs great unloaded. Just ordered a new aluminum radiator last night and if that doesn't cure it, I guess back to the shop to get looked at further.
You might want to look into the manual fan control-http://www.powerstroke.org/forum/general-6-0l-discussion/752514-manual-fan-control-mod-question.html
The 6.0's fan strategy basiclly (IMO) sucks. The truck will start getting into a high heat situation and the fan sits therr doing nothing .I finally got tired of waiting for my fan to decide to kick in an ran the BPD 7.3 fan mod. But short of that the manual fan control is the next best thing.
If the radiator doesn't solve it I'll have the shop that just did all of the work look into it further. I want to keep the stock fan so I don't get any check engine lights. I guess if nothing else I'll just continue to do upgrades.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
