Loss of power....and mind - Ford Powerstroke Diesel Forum
Old 01-10-2009, 11:01 AM
I have a 2004 f-350 with the 6 liter and just got it out of the shop after a month and several thousand dollars. The problem I had was when you hit the accelerator it cuts in and out and when you let off you hear a slight grinding noise, almost like a wheel rubbing, but it isn't. At highway speed it runs fine for a while, but the starts sputtering and every once in a while you hear that grinding noise. I am at a loss. The mechanic told me that it had to do with the egr cooler, but the engine temp is fine and I am not losing coolant. Any one know?
Old 01-13-2009, 03:14 PM
Powerstroke Diesel Enthusiast
Sounds like a turbo issue, feel like pulling your turbo apart and inspecting it?
Old 01-19-2009, 03:17 PM
Thats exactly what i thought, iether a unison ring seized or the vanes weren't opening, but they kept insisting that it was the egr cooler. I tore the truck apart and it didn't even have a cooler, it had a bypass kit. Now they are telling me that it is messing up because of the bypass kit even though it has ran for months with it on. I would really like to take apart the turbo and look at it, but they have my truck at the dealership, where it has been for a month and a half, and they won't let me take it out because they are always checking something or taking something apart.
Old 01-21-2009, 08:23 AM
Send a message via Yahoo to unclwoodman
I just got my 04 out of shop. Same symptoms. They replaced Turbo and EGR. Said turbo was cracked.
Old 02-22-2009, 07:14 PM
was it smoking sounds like what mine is doin if it smokes
Old 02-22-2009, 07:46 PM
TURBO Is going
Old 02-23-2009, 07:24 PM
TURBOS ARE BAD ABOUT INTERMITANT TURBO PROBLEMS INCLUDING THE BEARINGS. ITS WIERD I NO BUT I HAVE SEEN THIS ALOT
Old 02-24-2009, 06:32 AM
Sorry for delay in response. Yes it was intermittent and it did smoke. Seems fine now.
