HELP!!!! 04' F350,. AUTO STOPED RUNNING? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-09-2009, 04:22 PM Thread Starter
KILLER KEN's Avatar
Hi all, I have a 2004 F350 crew cab with 6.0, automatic. It has 104000 miles on her and today she just died on the x-pressway. Code came up P2290 injector controll low fuel pressure. I run a superchips 1805. I downloaded the stock tune right befor the tow truck came, so the code is now gone. I had to have it towed to a dealer where i bought it 4 years ago. I changed the oil, oil filter and fuel filters in the middle of october. I always keep it full of fuel and buy good fuel. I also use cetine with antijell additve in the winter. i have not had any problems with her since last january when they finaly found a shorted wire in the harness (used to loose throttle responce all the time). Is there anything i can check on my own? I'm going to check the fues in the morrning (it was to dark tonight). could it be a relay? if so what one is it? what else can i check. I'm a old mechanic turned plumber, if it was gas i would have no problems fixing it. I do all my own work except when it come to the diognostic part on a diesel. Pleas any info would be greatly apriciated. Ken Iamele
2004 F350 CREW CAB SHORT BOX 6.0 5 SPEED AUTOMATIC 4X4 SRW WITH CAP FOR WORK, A TICK UNDER 9000 LBS. K&N COLD AIR KIT, SUPER CHIPS 1805 IN PERFORMANCE MOST OF THE TIME. 305/65R16LT TIRES. RAN 14.83 IN EXTREME MODE IN 4X4
KILLER KEN is offline
post #2 of 14 Old 01-09-2009, 06:13 PM Thread Starter
KILLER KEN's Avatar
dose anyone have any sujestions? what to look for or check? fuel pump?
post #3 of 14 Old 01-09-2009, 06:14 PM
Lonno's Avatar
Bump for tech help.
1970 F250 Crew Cab rebuilt/restored w/Cummin s 4bt
8v, M5R2 Tranny, VE pump, DennyT stage 2 pin, M&H Dynamic Timing, 3200k gov spring, Hx30/Hx35 Twins, 40hp styx, smoke screw screwed, star wheel cranked, Hydroboosted
91 Gillig Phantom, Converted transit bus, 6v92 Detroit Diesel
6500 Watt Diesel Generator on board
All Diesel
All Day
Lonno is offline
post #4 of 14 Old 01-09-2009, 06:15 PM
TXbroker's Avatar
Cam Position Sensor, check the 6.0 tech files.
I dont know the code but teh symptoms sound as such
Paul
2005 F250 4X4 CC 6.0 FX4 Lariat
All stock
Lots of Toys, cylinder count is now 31:
TXbroker is offline
post #5 of 14 Old 01-10-2009, 04:20 AM Thread Starter
KILLER KEN's Avatar
ANY IDEAS OUT THERE?
post #6 of 14 Old 01-10-2009, 08:33 AM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
P2290 is a code for low ICP (Injector Control Pressure). Is this an EARLY build '04 or LATE build '04 model year?
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #7 of 14 Old 01-10-2009, 08:36 AM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Cam sensor failures are only common on 7.3L models for which a recall already exists, covering all 1997 to 2003 model years.
m-chan68 is offline
post #8 of 14 Old 01-10-2009, 11:09 AM Thread Starter
KILLER KEN's Avatar
I'm not sure if its a early or late. When i go to the dealer i'll take a look at the door. If i remember its a early one.
post #9 of 14 Old 01-12-2009, 04:55 PM Thread Starter
KILLER KEN's Avatar
Dealer called today, HPOP went bad. The problem is everyone told me that the truck should have shown signs of it going bad, like loss of power, rough running ect, it was fine, no problems at all, just shut off while driving, like a gas motor ignition modual going bad. Oh well its only $1400 to fix it. (P.O.S. FORD).
post #10 of 14 Old 01-12-2009, 04:58 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
It shows lots of signs. Just hard to catch them all in the .03 seconds when it decides to finally let go. Some times they will be a no start hot but when they blow going down the highway they blow.
