As of now the codes I have are p006a map sensor code, p2285 I think it is which is icp sensor sir unit low and p132b.. I hade a buddy hook his snap on motis to it and the icp at idle was 636 psi which I think is normal I wa reading you need at 50 for truck to run.. I check ipr that was at 24% hot idle my ficm was reading 47.5 volts. My truck starts up easily every time and haven't had an issue with that yet. I maybe leaning toward injectors now not sure how to read if they are bad any info would be great. And at wot and sometimes half throttle truck falls on itself surging no boost. This is really killing me at this point I have the egr delete already egr valve, turbo and 4 injectors were replaced last year. And does anyone have any other numbers or values I should be looking at on data and what good values would or should be? Thank
