07 heater only blows threw the defrost vents. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-30-2008, 07:28 AM Thread Starter
hello
I own a 07 f350 6.0L. Last summer the EGR cooler and EGR went and I had the mecanic weld up the new EGR cooler and not replace the EGR. i live in northern canada and my heater will not blow to the floor or out the dash vents no matter what setting the control is on it will only come out the defrost vents. Im not to sure if the EGR mod is the problem just thought I would throw the info in there. My feet are freezing please help and thanks in advance.
bouch_59 is offline
post #2 of 8 Old 12-30-2008, 07:48 AM
bfloyd4445's Avatar
Quoted: 3 Post(s)
Originally Posted by bouch_59 View Post
hello
hope this helps
Britt
2007 F250 CC SB 4X4, SB, PSD, Lariet, stock
1975 Ford 2000 ROP Diesel tractor < ran without oil for 2/10 mile 7/12/2009> Stills runs as good as ever
"If you don't read the newspaper you are uninformed,
If you do read the newspaper you are misinformed."
-Mark Twain
bfloyd4445 is offline
post #3 of 8 Old 12-30-2008, 08:13 AM
sikktruk01's Avatar
sounds like you have a vacuum leak, possibly knocked something loose when doing the egr
platinum edition F250 crewcab, 7.3 powerstroke,8 inch fabtech, 37x13.5x20 kumho m/t, 20x10 A/R teflon thug,6 FOX shocks and stabilizer, stainless toolbox, line-x, 4 inch exhaust, AEM intake, wicked wheel, Dp-tuner, Autometer C2 Gauges, kenwood in dash TV/DVD with navigation, sirius, bluetooth and back up camera, infinity and JL audio speakers, PPI amp, 08 diff cover, braided brake lines, onboard air w/ train horns,E-Z down tailgate
sikktruk01 is offline
post #4 of 8 Old 12-30-2008, 08:14 AM
SuperCrutyPS's Avatar
Quoted: 318 Post(s)
Garage
A Vacuum line maybe? I'm pretty sure the flaps are moved by vacuum redirected by how the switch is set.
Any of that messed with during the EGR work?
Just a thought.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #5 of 8 Old 12-30-2008, 12:42 PM
Heartbeatracing's Avatar
I know that most cars air controls default to the defrost if there is a vacuum problem, not sure on the Ford trucks tho....I would be looking for a vacuum leak as the others stated
Heartbeatracing is offline
post #6 of 8 Old 12-31-2008, 05:19 PM
Bob Q's Avatar
All though I don't know which one it is, it's a fuse. Had it happen on a 2000 f-350 PSD.
Bob
Bob Q is offline
post #7 of 8 Old 12-31-2008, 05:41 PM
kornfed's Avatar
I would have to go with vacuum also I test drove a truck before I got mine and it did the same thing had them fix it before I bought it and they said it was a vacuum leak, then found mine and didn't buy there truck oh well
2004 F350 Dually
Ex. Cab 4x4 Long Box
6speed 6.0L
Airaid filter and cold air
Zoodad
4in. Banks monster exhaust with no cat to 5in. tip
SCT x3
Autometer Z series gages and duall pillar pod
kornfed is offline
post #8 of 8 Old 12-31-2008, 07:50 PM
Articcatzl440's Avatar
i have a 05 psd lariat with climate control and mine did the same thing the dealer had to replace a fan sensorand that did it
Articcatzl440 is offline
