Issue with brake lights - Ford Powerstroke Diesel Forum
post #1 of 14 Old 12-28-2008, 05:06 PM Thread Starter
dmalmgre's Avatar
Hi guys, I'm having an issue with my dad's '04 F250 Extended cab long bed 6.0. His two rear brake lights stopped working. His upper 3rd one still works however. I was wondering if anyone had a link to a wiring diagram for this truck or any good advice. Thanks for any help!
2004 Ford F250 SD Crew Cab 6.0 PowerStroke 4x4
-BPD Oil Cooler
-BPD EGR Cooler
-SCT Livewire TS
-SRL Tune (Gearhead Performance)
-Blue Spring Mod
-Fabtech 8" lift (dual stabilizer, dual front/single rear Fox Racing shocks)
-20" Weld Racing Wheels
-37" Toyo Open Country Tires
dmalmgre is offline
post #2 of 14 Old 12-28-2008, 05:07 PM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
Did you check the bulbs?
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #3 of 14 Old 12-28-2008, 05:11 PM Thread Starter
dmalmgre's Avatar
Haha yes. It's a wiring issue we suspect... We just need a wiring diagram...
-BPD Oil Cooler
-BPD EGR Cooler
-SCT Livewire TS
-Blue Spring Mod
dmalmgre is offline
post #4 of 14 Old 12-28-2008, 05:20 PM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
I don't have a diagram, but its pretty straight forward. Wires go to the back of the truck. I can get a diagram in a few days if you still need it then.
BPS President
Jake is offline
post #5 of 14 Old 12-28-2008, 05:37 PM
The electrical connector coupler under the bumper on the drivers side probably has debri in it. Unplug and clean the connections and see if that fixes it. Mine did the same exzact thing 3 weeks ago.
2005F250 is offline
post #6 of 14 Old 12-29-2008, 09:57 AM Thread Starter
dmalmgre's Avatar
Yeah that manual would be awesome if you could get it. We checked and cleaned the connection under the bumper.
-BPD Oil Cooler
-BPD EGR Cooler
-SCT Livewire TS
-Blue Spring Mod
dmalmgre is offline
post #7 of 14 Old 12-29-2008, 09:58 AM
CoalRollinRoosterCruiser's Avatar
Did you check the fuses?
Jonathon or John Although technically i have a list of nicknames the length of I-95, so call me what ya like
Current Truck--1999.5 F350 ext cab short bed SRW Lariat 4x4 ZF-6. 4" lift, 35's, exhaust, intake, chip, and more.
CoalRollinRoosterCruiser is offline
post #8 of 14 Old 12-29-2008, 10:11 AM
BeaufortBiofuels's Avatar
When you get the diagram, first thing is to check the ground.
BeaufortBiofuels is offline
post #9 of 14 Old 12-29-2008, 11:11 AM
SuperCrutyPS's Avatar
Quoted: 348 Post(s)
Garage
Don't know where you're located, but I picked up a Chilton's Manual for my '01 at my local parts store. The Chilton's has wiring diagrams in it. Check around the parts stores in your area, may be able to score one!
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #10 of 14 Old 12-29-2008, 02:32 PM Thread Starter
dmalmgre's Avatar
Yeah we're thinking about picking up a Chilton's but we figured if we could get the diagram off the internet for free it'd be even better . No luck soo far. Yes the fuses have been checked...
-BPD Oil Cooler
-BPD EGR Cooler
-SCT Livewire TS
-Blue Spring Mod
dmalmgre is offline
