Battery Problems
After not quite two years my batteries are not staying charged. It happens most when it is cold. I am charging one of the batteries. I have two questions:
1) Is 2 years the average time for battery life on PSD's ? 2) Do I only have to charge one of the batteries, and the other battery will charge automatically since it is connected via cables. Thanx Bob~! |
if its not around alot of cold then they should last alot longer than that. but idk. are you running alot of aux stuff on ur truck?
Not REAL cold here in Houston. I do not have a lot of auxiliary electronic.
hhmm.. i got nothin lol.
for my lack of info
Battery
We have the same probolem with the wreaker at work with a 6.0 I will try too find out what the rapair was.
They should last for years and i woulkd replace them as a pair. If your truck is two years old it is under warranty so take it to the dealer to have sorted out |
Mine were slow to crank and would drain down quickly with the radio on while working, after just 2 years. I did not replace under warranty
![]() The new ones make a big difference. |
