Wireing 07 F250 - Ford Powerstroke Diesel Forum
Old 12-25-2008, 05:46 AM
Wireing 07 F250
For those if you with a 2007 Reg cab F250 or others i would think....Check the wiring under the drivers side battery. Mine was shorting out and i had no idea till it rained hard or drove in slushy snow....Had to have it towed as it screwed up the main wires going in to the computer on drivers side fender. Wires were UNDER the battery base and crunched and wore a hole in them.
dealer than fixed and put them back where they were. (guess they wanted me back after the warrenty wore off) It was the first set of wires that come out and head down the inner fender. and i see where they played with some others down further. what happen was ENgine lite was flashing,Tow haul lite flashing,and tranny was like someone was pulling you in other direction. seems mine has a braker in it where some have a fuse. i guess when that blows you change puter.
Old 12-25-2008, 05:53 AM
Send a message via AIM to zippy557
i'll have to check on that and see if mine are under the battery ...
