I have a 2006 F350 PSD. 8" lift 37" tires. Been driving it for 5 years like this and the truck now has 110K miles on it. Feb 1 the steering wheel locked up and would not turn. It was towed to a ford garage in CLT. They replaced the power steering pump and it worked normal again,
On Feb 15 the passenger front u jount ripped itself out of the truck and at the same time the steering locked up again. Towed to the ford garage in PIT. They replaced the u joint, short and long passernger front drive shafts, front right ball joints, power steering pump again and the power steering gear box.
The truck is very hard to steer after it left the ford garage. On Feb 25 the Hydroboost unit was changed. No effect. Removed the power steering cooler and put a bypass hose in its place for trouble shooting, no change. Cleaned the filter in the resivior, no change. Fluid clean, fresh and red in color.
When the front end is jacked up the steering works good until you apply the breaks and the steering is hard to turn. If you boost the RPMs up to 1200 everything works good.
I lubed every front end joint last night and this morning in reverse the steering worked flawlessly but in drive still have the same issue. Help
With the truck jacked up and you press the break the steering gets hard to turn. If you put the truck on high idle while jacked up everything works good.
I dont have a manometer. I will schedule in to try to get the pressurers read. Ford has not been any help. This system is fairly straight forward, im leaning towared a colapsed line. I dont think any of the lines are coming apart because the oil and filter have been clean.
Do you still have brake pressure? Can you make a 60-0 stop??
If you can, it means that something between the Hydro and the Box is not ok, probably the pressure is not as much as you need to operate both of them, you need 2500PSI, or probably the pressure line from the Hydro to the Box is collapsed
Good info! I can stop quick even though the truck weighs 8k lbs. I cant get it in to check the pressurers for a few days, I may just replace that line.
To all that read this. Auto Zone has the hose that goes from the pump to the hydroboost for 23.99 and the hose that goes from the hydroboost to the gearbox for 19.99. Hope to change these out this weekend and see if it fixes this problem.
Replaced both of these lines and the steering is 80% better. Truck now at Ford of Huntersville NC for a steering pump pressure test (hopefully) and a warranty pump change if needed.
The Ford dealer in Huntersville NC is useless on trucks. They did not have a pressure gage to test my power steering pump pressure and said after a few days of the truck being there that they could not help me. Truck now at Town and Country Ford in Concord NC.
So to finish this post, the day I was going to pick the truck up from Huntersville ford and take it to Town and Country Ford, Huntersville Ford call me and said there was a miss communication and that they would fix the truck. They put another power steering pump on it and it drives now like a new truck. $3k, complete new power steering system and the truck steers again. To the person who is rebuilding these Ford power steering pumps, you suck.
I did read the entire thread, I just miss read the last post.
I just think it's crazy what they charge to do some of the work these days. A buddy of mine was quoted around $500-$600 to replace hi powersteering pump on his 05. I laughed because I replaced mine on my 04 for lest than $75 and about two hours of my time.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
