Rough running - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-21-2008, 06:21 PM Thread Starter
Question Rough running
When the temp dropped below freezing my 2005 f-350 6.0 would start just like normal, but after about 10-15 seconds it would act like it was missing. This would last for a few minutes then it would run normal. About a week ago it was a lot colder than it had been and it acted the same way then after about 12 miles it started to run like it had a bad miss then it acted like it had run out of fuel and just died. I could start it after a couple minutes and it would run rough and die after about a mile or two. I changed both fuel filters and after starting it and allowing it to run at idle for quite awhile I shut it off. The next day it started right up like there was never anything wrong with it. after letting it idle for about 10 minutes I took it for a drive around the neighborhood and for about 10 minutes it seemed ok until I decided to take it out on the highway and give it some pedal. It started to run rough and eventually died. It did this two more times in about 5 miles before I got it home. Any ideas?
Saddlebum13 is offline
post #2 of 4 Old 01-08-2009, 07:15 AM Thread Starter
fixed it
I finally took it to the Ford garage and they replaced two injectors. Now it runs like it should. That makes 3 of them in 2 years. How do you keep it from going through injectors?
post #3 of 4 Old 01-09-2009, 06:16 PM
Spoolin05Stinker's Avatar
Location: not to far from the city of "Brotherly Loved"
Try to stick with one fueling station and run some diesel additives
2005 F-250
4"Mbrp With Cat
33x12.5x17 MT BAJA MTZ
Autometer Boost, Egt, Trans gauges
Green Drop in Air Filter
ARE DCU Series Cap Trucks gotta make me Money
MSD Daswhawk for the other parameters
Spoolin05Stinker is offline
post #4 of 4 Old 01-10-2009, 10:28 AM Thread Starter
A friend told me to use Diesel Fuel supplement w/Slick Diesel in the winter to help prevent gelling when it will be below freezing. I never thought to use it all year long, I will do that from now on.
Thanks....
