6.0 cold start trouble.
I have an 05 6.0 psd with about 45k. i work second shift can't plug truck in while at work. its gotten down to about 22 degrees so i let it glow 2x before attempting to start. when i let it glow i hear the clicking sound... whatever that is. Anyway when i went to started tonight, it acted like it was gonna die and started blowing some serious smoke. After about a minute it seemed to run ok. When i plug it in it starts right up... Anyone have any idea, maybe glow plug relay?? If so can someone tell me where the gpr is located. Sorry but i'm sorta a diesel newbie...
Mine does the exact same thing except for my batts usually die when it gets cold out too for some reason?
take this truck to ford and have the inductive heating reprogram done , doesnt have a glow plug relay , has a module and they dont tend to give problems , the reflash should take care of your problems
one thing to remember as well , the glow plug light and actual glow plug on time are 2 different things , glow plug on time is controlled by engine oil temperature , the light only stays on for up to 10 seconds , but glow plugs are still on, cycling the key is a waste of time |
I used to cycle the key a couple of times in the morning and wound up blowing the gasket on my fuel filter.
so in the mean time till i can get to a dealer will leaving the glow plugs on for a bit longer help?? if so how long do u suggest?
the reflash helps a ton! and it doesnt even get that cold down here.
yes that can help , even after starting the glow plugs are still on up to 90 seconds depending on temp ,but yes to answer your question , waiting another 15-20 seconds can help
awsome thanks. one more thing and its probably stupid, but is dealership gonna charge me for reflash?
I had to pay around $90
but it really does help.
some do, some dont , we did if it was out of base warranty , after 36,000 then its chesaper than the deductible , so they probably will , just call them and ask them
