Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 12-08-2006, 12:48 PM
Roadking Roadking is offline
o4 6.0 Stumbles when accelerating, Why?
This is a 35000 mi truck. My first diesel. Has 5" K&N Intake and 5" SS Exhaust. I am not aware of any other mods as I bought it used.
I can handle Turbo Lag or Spooling up and this is what the sales mgr told me I was expieriencing. But it was not. Upon acceleration the truck would stumble. As if it was stalling with no throttle response. Would also give a puff of white smoke and then take off. Took it in and they found that the throttle position sensor needed replaced. On the way home it stumbled once briefly... Thought it was clearing it's throat so I tried to forget about it. About 40mi from the dealer I slowed down for a right hand turn. Guess what! It stumbled real bad after I made the turn. Seemed like an eternity, but lasted for about a minute, huffed alot of smoke mostly white and then started responding to the throttle again. Drove to the destination about 1mi away and shut er down. Came out in a little bit fired it up, took off down the road sputtered a few times and when I turned right onto the main road again it stumbled.
I cannot find a combination of factors that will duplicate this on a regular basis. Although it seems to happen more when it is hot than cold. Are there other 6.0 owners expieriencing these symptoms? If so what have you found to clear them up?
Roadking
Old 12-08-2006, 12:51 PM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
I would bet its a dirty EGR vavle. You can pull it and clean it in 20 minutes.
Old 12-08-2006, 12:52 PM
Oh, and...
to Powerstroke.org!
Old 12-08-2006, 12:55 PM
thunderinms thunderinms is offline
Sic Semper Tyrannus
Send a message via Yahoo to thunderinms
+2 on the EGR valve. I had the same issue. The Dealer took care of it for me. It may be a recall. On the 04s, make sure you get all of your recalls and flashes down. Mine has worked super since I had it flashed.
GG
Old 12-08-2006, 01:01 PM
Wow! You guys are fast. I will check it out. Thanks in advance. Roadking
Old 12-08-2006, 01:21 PM
I looked, I saw, but I have no idea what I am looking for. Or where it is at for that matter. Can I flush it out with solvents? I little direction would go a long way at this point. Thanks soooo much for your help. Roadking
Old 12-08-2006, 01:35 PM
Give me a minute and I'll post up another thread that will help...
Old 12-08-2006, 01:36 PM
dustindiesel dustindiesel is offline
just a question to add to the topic.....do u need to replace the rubber orings when u pull the valve?
by the way its the cylinder type piece with an electrical connector on top located on the left middle when u are standing at the bumper.its got 2 small bolts holdin it on...mine was a pain to get out so i gave up, i will defeat it this weekend
Old 12-08-2006, 01:39 PM
Heres a link to another thread that will explain it.
the O-rings should be replaced however, last time i did it, i didn't replace them and I had no problem so far.
Old 12-08-2006, 05:11 PM
My immediate seat of the pant reaction to the cleanup of the EGR valve is........... if you haven't done it, do it. You will not regret it. Granted I have only owned this truck for about two weeks but it has made a noticable difference. Thank You so much.
