Cleaning inside of intake.... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-01-2014, 04:03 AM Thread Starter
bassn5150's Avatar
I'm doing an oil/egr cooler after finding moisture inside the intake. I've got everything apart and cleaned up except for the inside of the intake. My question is this; what is the best way to clean the inside of the intake and get rid of all the wet carbon? I was lucky, I caught the problem early, and the intake is not filthy but it needs cleaning. Thanks for any help!
bassn5150 is offline
post #2 of 5 Old 04-01-2014, 04:45 AM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
If you have any sort of machine shop nearby, they should be able to hot tank the intake manifold to remove the carbon buildup.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #3 of 5 Old 04-01-2014, 07:44 AM
mikegoslin09's Avatar
Pressure wash then hot air to thoroughly dry it
2004 F350 6.0L Powerstroke FX4
72,000 miles and climbing
4" MBRP turbo back to 6" stack
SCT SC3, tunes from Eric @ Innovative Diesel
Edge Insight CS
GlowShift Boost, Fuel Psi, 2400* EGT gauges
Blue Spring Mod
Zoodad Mod
Venom Wheel 2" spacers.
Edge Insight CS
Blue Spring Mod
Zoodad Mod
Still running Ford Gold with great deltas, good coolant pressure. Healthy truck.
mikegoslin09 is offline
post #4 of 5 Old 04-01-2014, 08:06 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
You may want to delete the EGR Cooler since it may be leaking.
AshevilleEngine.com is offline
post #5 of 5 Old 04-01-2014, 05:48 PM Thread Starter
bassn5150's Avatar
Went with BPD EGR cooler. Factory oil cooler. Since my original post, got the intake pressure washed and ready to bolt back in. This is my first 6.0 to get into. So far, it hasn't been as bad as I thought it would be.
