Multiple coolant leaks: what's the problem? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-31-2014, 05:11 PM Thread Starter
Ok so I started noticing random leaks in multiple places under the truck, so I went in for a closer look.
Nothing leaking around the degas bottle; deltas are good, performance is fine, egr not leaking.
Turns out I've got leaks all over the place. Some are clearly coming from various connection seals (mostly around the radiator), others I haven't been able to pin down.
I've taken pictures to illustrate:
These are from below the radiator:
[IMG]hhttp://i1224.photobucket.com/albums/ee364/djmccoy77/PhotoMar3172729PM_zpsb8322300.jpg[/IMG]
Below fan
Passenger side hoses:
This one is directly above the front differential, which I assume is a connection to the water pump:
There is another above the driver frame rail that I can't see.
Is this simply a bunch of failed seals and hoses or something more sinister at play?
Truck has 250k miles, and is not driven very much. Leaks only occur when truck is hot.
rawdeal is offline
post #2 of 2 Old 04-01-2014, 04:09 PM
4506.0's Avatar
The last picture is power steering fluid, from the pump or line. Not coolant.
The passenger side hoses look like the tranny cooler lines. Not coolant.
Can't really tell what the pic before the power steering pump is.
First pic that shows looks like radiator hose clamp or radiator is leaking.
16 F350 CC LB DRW 6.7 FX4
4506.0 is offline
