No Throttle Response - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-28-2014, 11:22 AM Thread Starter
07, 6.0 diesel. Runs rough at idle at times. Has seemed to happen more often. The last drive it was rough at idle backed it into the garage put in park and had no throttle response. Floored the throttle truck stayed at idle. Shut it off tried to restart no luck. Let it sit 4 hours came back started and had throttle response? Truck has 70k miles and has not been mistreated, did have to replace the frame rail fuel pump last month. Other then that truck is original. Thanks for any help in advance.
ayala160 is offline
post #2 of 3 Old 03-29-2014, 05:37 AM
4506.0's Avatar
Do you have anything to read data or codes?
16 F350 CC LB DRW 6.7 FX4
4506.0 is offline
post #3 of 3 Old 03-30-2014, 05:27 AM Thread Starter
I had two codes both PO299, turbo under boost.
ayala160 is offline
